dougrainer
Jan 19, 2015Nomad
1. IF you have REV E, then the likely cause is a false trip OR a leaking cooling unit. Older REV's could be tripped by 12 volt fluctuations.
2. The RV tech should do a thorough check of the burner area especially around where the recall temp thermistor is mounted for yellow residue. The past few that I have seen, that is where the leak was.
3. Are you positive the ventilation is clear from bottom to top? Doug
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
