USMC46
Jan 20, 2015Explorer
OK, time for an update and to seek more advice. I did get the temp control switch to reset. Last night at around 9:00 P.M., I started the fridge up on AC. After about 13 hours or so, the freezer is only registering a little over 50 degrees. I would say it is not cooling correctly. So, SHOULD I try it on propane, or just assume that will not work either ? The pipe running into area where the propane ignites is very hot, so something is heating up the line. The round tank like unit does not seem to be hot or cold. Is the tank supposed to be getting hot ?
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
