jpratt2
May 24, 2017Explorer
Thanks for all the info everyone! So it sounds from the replies that it depends on the age of the converter/charger system. This is a 1998 Bigfoot 29' Garage model that most likely has its original charger, so I should probably get a timer. Additionally a previous owner hardwired a regular battery charger into the system...probably for a fuller charge.
Also sounds like I need to monitor the water levels...a PITA as the deep cycle batteries are stuffed in there pretty good. Anyone use the self-watering systems that keep them topped up?
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 28, 2026
