candjmc's avatar
candjmc
Landing gear problems
Hi all I have 2010 28ft cougar 5th wheel
My landing gear pops fuses
Batteries fine but I believe this motor model1a065012-02-01is something the original owner had swapped
From what I can tell its 5000lb lift. The 30 amp fuses will pop after 5 seconds maybe quicker.
I am hopeful someone can help me.
  • The rocker switch could be bad. it has contacts that wear out and you then need a new switch. Doesn't mean it blows fuses, but it might. ? It can just not work right.
    If anything like the in/out switch wiring for the slide, it is complicated wiring and you need to put the right colours in place with the new switch. Best to take a photo first or make a drawing.
  • That is the model number for a Stromberg Carson Landing Gear Motor rated at 5500#
    It is/can be used on Atwood, Venture, Lippert landing gear systems
    Part number is LG-142178
    It sounds more like the Up/Down Switch is your issue
    Part # (LG-145236)
    Replacement Switch
    There are only 2 wires on motor
    Black & Red
    One is for UP and one is for Down
    4 wires on switch
    Pink...DC+ from Battery with 30A In-line Fuse
    Red....Goes to Red on motor
    Black...Goes to Black on motor
    Black,,,,,,,,,,this is the DC- to battery
    Wiring Diagram included with new switch
Having RV issues? Connect with others who have been in your shoes.24,191 PostsLatest Activity: Jan 19, 2025
