candjmc's avatar
candjmc
Landing gear problems
Hi all I have 2010 28ft cougar 5th wheel
My landing gear pops fuses
Batteries fine but I believe this motor model1a065012-02-01is something the original owner had swapped
From what I can tell its 5000lb lift. The 30 amp fuses will pop after 5 seconds maybe quicker.
I am hopeful someone can help me.
  • Will it move by the hand crank ok? If not and is jammed the motor fuse could blow.
    Is there a wiring short like a cut in the wire's insulation touching?
    Is the up/down switch shorting in the back of it with all the wire contacts there?, Had that with the in/out switch for the slide in the 5er we had. Same kind of switch ISTR. New switch fixed that.
Having RV issues? Connect with others who have been in your shoes.24,312 PostsLatest Activity: Sep 06, 2025
