landyacht318
Feb 06, 2016Explorer
The molded connector field terminal tabs are more than 1/4 inch thick, the next size up quick connects are loose and wobble. Even if squeezed with pliers I can pull them off all too easily.
I want to be able to return the OEM VR to duty easily if I have to, So ring terminals it will be.
I saved some threaded brass contact and screw from a Switch I wore out. It has a nice wide flathead brass screw and will hold ring terminal to Connector tangs nicely.
I will use some wire insulation over the field terminal studs preventing accidental contact.
Guess I should get to it rather than type on this **** laptop
