MM49 wrote:
Go with the max pressure. When you weigh a RV on a truck scale you get a weight of the total axel. You really need left to right weight also. Many times RV's are not balanced. My RV wore the tires out faster on one side because of loading. All of the equipment.kitchen, fridge, furnace and pantry are on that side.
MM49
X2...I remeber learning about high performance suspension setups when I was younger and the one thing that left an impression was balnceing the suspension which is basically putting the vehicle on 4 scales to measure the weight of the suspension and adding or removing shims to equalize the suspension.
