dclark1946's avatar
dclark1946
Late 80's RV Questions
I have offered to consult with a young couple in our neighborhood that just purchased a late 80's Class C motorhome but have no previous experience with RVs. All my experience is with TTs starting with our first new one purchased in '99.
After meeting the couple, doing initial RV checkout and going over some of the basics with them, I have a few questions.
The range and oven function but I was puzzled that the oven control had a pilot position but you did not have to push the temp/pilot knob to light the pilot while waiting for the thermocouple to heat up. The pilot lit and the burner operated when rotated past the pilot setting.
The house battery is in the Ford van engine compartment on the driver's side but only measured 7 volts (engine off) while the engine battery on the passenger side measured 12.5V. The house battery was getting charged once the engine was started but it is going to need replacement due to age and state of discharge. How is the house battery typically isolated from the engine battery when the engine is off? The coach battery monitor read "all lights on" but the LP detector correctly had a low voltage light on. Both should have read low battery with engine off. Is it possible that the coach battery monitor was measuring the engine battery rather than the house battery?
Thanks,
  • That range setup is not unusual, or at least was not unusual relatively recently. There are two valves to control the oven, the thermostatic valve (which the knob attaches to) and a safety valve (hidden in the back somewhere). The pilot flame is on whenever the thermostatic valve is not off, but it varies in size: if no heat is being called for, it's a tiny little flame, but when the thermostatic valve detects it needs to turn the oven on, it increases the gas flow to the pilot and turns on gas to the safety valve simultaneously. There is a bulb by the pilot that controls the safety valve; when the bigger pilot flame warms it enough, the safety valve opens and the main burner gets gas and lights. Once the proper temperature is reached, the thermostatic valve closes the gas to the safety valve and cuts the pilot back down to a little flame, and the safety valve soon closes when the bulb cools off.
    It is possible for the pilot to go out and still have some gas flowing to the pilot burner with this setup.
  • New Fords have a relay that is opened/closed with the ignition circuit power (key in run position), don't know how far back that goes. That would isolate the coach battery.
    Idiot light battery monitors are notoriously bad. Installation of a simple voltage gauge is cheap and fairly accurate.
Having RV issues? Connect with others who have been in your shoes.24,288 PostsLatest Activity: Jan 09, 2022
