MEXICOWANDERER
Apr 05, 2021Explorer
29, 30, and 31, are acid starved specials, just like 65's and 34's.
They scrape by in engine starting duty but fall flat on their face if cycled. A real hoot was Delco's calcium/calcium sealed RV battery. Known as the single cycle special. After 1 discharge the "eye" stayed red until shortly after when the battery played possum.
The mark of a crappy quality battery is flaky hydrometer readings. They reflect poor capacity, horrible charge efficiency factorials and early death. The battery regresses to its evil habits very soon after a lengthy equalization. I have had scumbag brand golf car batteries revert to .03 differential 5 cycles after equalization. Six months old. The owner of the Screwy Battery described a charge regimen of jamming 200+% electricity back into the battery. Pretty much a disaster as far as Charge Efficiency Factor is concerned. Using CEF to determine health of a battery is a good way to stay out of the swamp. This is true for any rechargeable battery including lithium with all of the variants. If a battery advertises CEF of 1.15 and you find yourself at 1.26 Houston, you have a problem.
Having RV issues? Connect with others who have been in your shoes.24,392 PostsLatest Activity: Jun 09, 2026
