proaspen's avatar
proaspen
Leaking Bathroom Sink
Own a 2006 Fleetwood Bounder 35E Class A MH. Rear bathroom sink was not draining well. I took it completely apart and cleaned out the gunk in the drain tube and P-trap. I'm a little familiar with home sink repairs, so knew I would need plumber's putty. However, the "putty" that was there was very, very sticky. I had to use a solvent to get everything cleaned up. This had me worried. I pressed on with "regular" plumber's putty. After a few weeks of having a dry paper towel under the P-trap, I thought I was golden. Then a leak started. it is coming from where the drain and the sink connect. Took it apart and it looks like the plumber's putty was, I wouldn't say dissolving, but something like it. I cleaned everything up and prepared to redo the plumbers putty. Read the container. Says not to use on plastic components! Use Oatey Sillicone Sealant instead. Having an issue finding the recommended putty locally. Everything I'm working on is plastic!! Maybe that's why the previous stuff was very sticky. I don't know what that material is. Need your help identifying. Gonna use the normal stuff just so I can get the sink operational. Will have to redo once I get the "correct" stuff.
  • Problem with RVs is when they are not used they get way hotter inside in the summer than a house and normal putty doesn't fare well. Example. Leave a candle on the counter of both your house and RV in August for a week....
  • agesilaus wrote:
    OK this search term: plumbers putty for plastic produced that page. You will find what you need there I hope.
    None of the plumbers putty on that page is for use on plastic. Your search is just hitting on "plumbers putty" and not "plastic".
    The Loc-tite stuff is for patching leaks. I strongly recommend people just do it right and skip junk like this.
    Never use plumbers putty on plastic of any sort!
  • You use putty on metal/ceramic or silicone on plastic drains where they attach to the sink itself. You dont use any of that stuff on the P-trap.
