DutchmenSport
Sep 14, 2019Explorer
I had a similar problem with a previous trailer, except it wasn't wet inside the compartment. Water ran out the bottom of the door itself. I never could figure that one out completely. Somehow, rain would seep into the inside of the door, flow to the bottom, and then when the door was lifted, would leak out the seam in the middle where the outer band met.
Perhaps yours is not leaking around the seals, but is leaking through the door itself. It's seeping in at the top of the door, flowing through the inside of the door, and found a way of escape, not on the outside, or through a weep hole in the bottom of the door, but actually inside the camper storage area. If the rubber seals around your door are sealed (The light test, as stated above, is a good way to check), then it's coming through the door itself. (or down the wall?????... roof leak?....)
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
