dougrainer
Jun 21, 2020Nomad
corvettekent wrote:
It is very common for this to leak as a RV water system is closed and when water is heated it expanes. Instead of replacing your relief valve add an expantion tank to your water system.
No, you add the missing air gap in the water heater. Doug
https://radioarizonarv.com/atwood-rv-water-heater-maintenance-tips-tricks/#:~:text=The%20Atwood%20water%20heater%20tank,water%20will%20absorb%20this%20air.&text=Allow%20pressure%2Dtemperature%20relief%20valve,turn%20on%20the%20water%20supply.
https://www.youtube.com/watch?v=JYSEaw1XRmQ
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
