wildtoad
Jun 21, 2020Explorer II
corvettekent wrote:
It is very common for this to leak as a RV water system is closed and when water is heated it expanes. Instead of replacing your relief valve add an expantion tank to your water system.
If the valve is not leaking around the threads, but instead is releasing pressure during the heating cycle, bite the bullet and do what this guy said to do. I fought with my Suburban wh for 4 years, trying different pressure relief valves, doing all the things they say to do to replenish the air pocket and none them helped a darn thing. Mine was the only Suburban wh I have owned through 5 RV’s and it’s the only one that had the leaking valve problem.
Suburban documents this in such a way to say it is normal, but they need to solve the problem. It was really disappointing to buy a $120k motorhome and have a brand new WH drip water when heating.
Finally I had a small expansion tank installed on the inlet side water line, and bingo bango bongo the problem was solved.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
