phemens
May 05, 2018Explorer
Leaking slide - missing seal?
We picked up a 2012 Dutchmen 5er (324lbs) last fall just in time to store it. I opened it up a couple of weeks ago to start mods and cleaning, so I extended the slides. This week, I noticed that the carpet in the bedroom was wet on the driver side (same as the wardrobe slide). I figured that some water got in as it rained a few days ago and we had parked the trailer in the backyard slightly inclined to the passenger side, so the rain must have found a path under the slide and into the trailer. I retracted the slide, dried the wet carpet and did not notice it get wet again when it rained yesterday. I plan to pull up the carpet this summer and replace with flooring anyways, so not a big deal.
Today, I checked all the roof seams and vents to make sure they were not an entry point (good there), then extended the bedroom slide again and checked all the seals. Looking underneath, I can see the rollers and there is no gasket on the bottom:
So, my question is, is that normal, or do I need to add a seal there? If yes to adding a seal, what is the best product and best way to attach (screwed & caulked, silicone, etc)?
On another note, one of my dogs took a tight corner around the trailer and ripped off some of the finish trim on a slide:
Can I get this from any RV dealer?
Thanks!
Thanks!
