rockhillmanor
Sep 25, 2013Explorer III
full-timer wrote:
Your roof may be sagging and the water is pooling around the air conditioner.Joe
x10!
Mine did the same thing. Called out RV mobile repair.
All it takes is a very small amount of sag around the AC to keep the condensation from running off. 'Especially' if you are anal about having the RV perfectly level when you are parked.
If it is 'real' hot out and sunny, the pooling evaporates. Cloudy days or cooler days it just sits there. That's why my leak was sporadic.
RV mobile repair fix for water leak?.......
Tip or lower one of your levelers.
I took out one leveling block on one tire and watched all the water run off the roof that was just sitting there dripping into the coach.
Which is why I like using RV Mobile Repair over dealerships. They have been there done that and not looking to charge you for stuff you don't need.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
