PatrickA51
May 14, 2014Explorer
profdant139 wrote:
After I drain the carburetor after using my Honda 2000, should I leave the drain screw open till the next time I use it, or should I close the drain while the generator is in storage? (I run it every month, with a 1500 watt heat gun attached to give it some exercise.)
(I tried to look this up on the archive and could not find an answer.)
Thanks for your advice!
I would run the Generator until the tank was dry.I would leave the drain screw alone. IMO
Having RV issues? Connect with others who have been in your shoes.24,351 PostsLatest Activity: Jan 19, 2026
