NinerBikes
May 15, 2014Explorer
profdant139 wrote:
Niner, I am not sure I understand why you are pulling the rope 15 times. Is that to prime the carb? (Forgive me if I am displaying my ignorance here -- because I am.) Doesn't that risk flooding the engine? (More ignorance. Oh, well.)
Thanks for clearing this up.
The Honda Eu has a fuel pump, it's not gravity fed it's fuel. So you need to pull the cord 15 to 20 times for the fuel pump diaphragm to give pulses to pump gasoline into the carb float bowl.
As an exercise, try it, and find out how many pulls it takes to prime the carb before the motor fires up after draining the float bowl. In a boat motor, you squeeze the in line bulb on the fuel line with one way valves to prime the carb float bowl with gasoline.
Having RV issues? Connect with others who have been in your shoes.24,350 PostsLatest Activity: Nov 11, 2025
