NinerBikes
May 17, 2014Explorer
ah64id wrote:
I currently own 2 EU2000s and had a different one several years ago. They all take ~10 pulls to fire once they have been ran out of fuel or the carb drained. It just takes that many for the fuel pump to fill the bowl. If it takes fewer pulls then the carb isn't dry.
This /\... sometimes mine takes 15.
You want to drain the carbs float bowl. Once that is empty, then you want to choke the carb so it can't suck air in on the intake stroke. This causes a vacuum from the piston intake stroke to draw all the fuel retained in the jets out of the jets and into the combustion chamber, where they can do no harm or leave varnish deposits. Now all your fuel jets are clear of damaging fuel and are cleared and only filled with air, a non varnishing material, while in storage, just like the motor and carb came from the factory.
Having RV issues? Connect with others who have been in your shoes.24,350 PostsLatest Activity: Nov 11, 2025
