oilcan
Jul 16, 2013Explorer
96Bounder30E wrote:oilcan wrote:
How can I tell if I have a charge wizard ?? I have a '94 Damon C class and am worried that if I leave it plugged into shore it will shorten the life of my battery.
Find your converter and then find the model number.........unless your converter has been changed out......a 1994 RV would not have a charge wizard........
If you have a Progressive Dynamics(PD) converter then you probably have a PD-9055.......this model does not support the charge wizard........
A 9160 or a 9260 is charge wizard capable.......
Thanks for the info.
Without a wizard is it not good to kepp plugged into shore power ???
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 17, 2026
