RJsfishin
Jul 16, 2013Explorer
Check the voltage at the battery or converter. If it never gets lower than 13.6, the converter is not very smart, and in warm weather will in time cremate the batteries, unless you watch the water closely. In colder temps, 13.6 - 14+ volts won't hurt the batts. My PD 9200 is always floating at 13.2-3
PD9100 series need the charge wizard added (plugged in) which makes it a 3-4 stage converter, and give manual control over the 3 stages
PD9200 series has the charge wizard built in, but still needs the charge "pendant" added (plugged in) to give manual control over the 3 stages.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 17, 2026
