- Golden_HVACExplorerHi,
Are you supposed to remove the ballast and connect the LED light bulb directly to the 12 volt power source, or still use the ballast and run them at the 1,000+ volts that the ballast can put out?
Just wondering?
And where did you get the bulbs (well LED replacements?)
Thanks,
Fred. - MrWizardModeratori've got one fixture with 3 strips of 21 leds
the others have 2 strips of 21 leds for the 30w fixtures
and 2 strips of 15 for the 18w fixtures
mine get kinda warm but not hot
neither the fixture nor the leds are as hot as when using the florescent tubes
we full time..so ours have seen daily use for about a month now
the fixture is the heat sink for the led strips
i stuck mine directly to the fixture.. No foam tape - SCVJeffExplorerThey do get very warm but wont burn you. Ballast resistors are built in but whats your supply voltage?
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
