- fj12ryderExplorer III
garyhaupt wrote:
Nah, you can find them anywhere online, I would imagine you can find them at a decent auto parts store, but I've not looked so can't swear to it. I get most of my stuff off Ebay. Good deals, good place.Chris Bryant wrote:
Might have to change the flasher to an electronic one, an easy swap, once you find them.
Finding the relay is problem?
Gary - garyhauptExplorer
hornet28 wrote:
I don't know what your budget is but here's an example of what's available.
https://www.ebay.com/itm/IPCW-95-12-Ford-Econoline-00-05-Excursion-LED-Red-Tail-Lights-Set-LEDT-502CR-/231908213771
Thanks hornet28...if I am seeing it correctly, it shows lenses and all full set-up...I have the original lenses...I just want to swap in the LED's.
Gary - hornet28ExplorerI don't know what your budget is but here's an example of what's available.
https://www.ebay.com/itm/IPCW-95-12-Ford-Econoline-00-05-Excursion-LED-Red-Tail-Lights-Set-LEDT-502CR-/231908213771 - Sam_SpadeExplorerWhy change ??
This is an honest question.
In some applications, there is little to no advantage to spending the time and money to change to LED. In my opinion, this is one of them.
Now.....changing the lights inside an RV to LED.....whole different situation and well worth the effort if you operate off the batteries much. - fj12ryderExplorer IIIYeah, it shouldn't be a problem, but as Chris mentioned will probably have to change out the blinker relay.
- Chris_BryantExplorer IIMight have to change the flasher to an electronic one, an easy swap, once you find them.
- Unless your E350 has bulb out sensing it should be as easy as plug and play. Or soo easy a caveman can do it.
Having RV issues? Connect with others who have been in your shoes.24,312 PostsLatest Activity: Sep 06, 2025
