rockwind1's avatar
rockwind1
Explorer II
Feb 23, 2019
LED BULBS going bad, bleeding to other circuits
2007 attitude 33' toyhauler
replaced all my bulbs in my trailer with LED's a while back and nothing but trouble it seems. worked great at first but then all the bulbs started burning out and they are supposed to last like a million hours or something.
they usually start flickering first, for a while and then they just go. the place i bought them said they would replace them but it's such pain to ship them back plus it's been a while so they probably wouldn't now.
the other thing is right by the front door there is a panel of abut 5 switches, one is for the main cabin which has 3 double lights on that circuit, and then another is 2 circular flood lights for the starboard? side of the trailer (which i also put LED bulbs in). however, whenever i turn on the main cabin lights, (at this point on 2 of the 6 bulbs are working), when i go outside, the flood lights are partially on, just kinda dim.
it's like some electricity is bleeding thru some how, even if the switch is off to the outside lights.
any thoughts on here? thanks
  • Cheap LED's have cheap drivers that make electrical noise. Like everything else in life, you get what you pay for. This is no exception.
    Average life is 100,000 hours, not a million. That entirely depends on the SMD quality and the driver quality.
  • I don't know which bulbs you bought from there. It doesn't matter where you got them as much as making sure you check the voltage specs for something like 10-35 vdc.
  • 2oldman wrote:
    You may have bought cheap bulbs that have a very low tolerance for fluctuating voltages like when your converter kicks on.
    i bought them here, http://www.m4products.com/led-rv-retrofit-bulbs/
    do you have any recommendations for a high quality place?
  • You may have bought cheap bulbs that have a very low tolerance for fluctuating voltages like when your converter kicks on.
Having RV issues? Connect with others who have been in your shoes.24,319 PostsLatest Activity: Sep 19, 2025
