- D_E_BishopExplorerThe replacement tubes are readily available in most RV stores or on line. They are spendy. Here is what I did instead.
Link
I saw today that COSTCO has two tube four foot fixtures on sale for $19.00. Usually happens twice a year. - RAS43Explorer III
jfkmk wrote:
MEXICOWANDERER wrote:
The 120vac 4' tubes require eliminating the ballast? Is there a preferred source of 4 tube fixtures?
Yes, the 4’ tubes require that you bypass the ballast, at least all the ones that I’ve seen. When I retrofitted my shop lights, I also had to replace the tombstones with non-shunted versions. Not sure of a freferred source, they’re pretty universally available.
I purchased replacement LED 4' tubes at Costco and didn't have to do anything but change out the tubes. It has been 2 years now and they still work fine. - jfkmkExplorer
Yes, the 4’ tubes require that you bypass the ballast, at least all the ones that I’ve seen. When I retrofitted my shop lights, I also had to replace the tombstones with non-shunted versions. Not sure of a freferred source, they’re pretty universally available. - fj12ryderExplorer IIII've seen them at Walmart, I would imagine they're pretty common. Not sure of the preferred source though.
- MEXICOWANDERERExplorerThe 120vac 4' tubes require eliminating the ballast? Is there a preferred source of 4 tube fixtures?
- JimBollmanExplorerI only had two fixtures so it hurt less. I also had free shipping.
- PuddlesExplorer
JimBollman wrote:
If your RV has the small T5 Florescent tubes here is what I put in mine and they are great. You do have to disassemble the fixture and remove the ballast and do some simple rewiring, easy to do.
https://www.amazon.com/gp/product/B0795NLGS2/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
$16 per bulb + shipping... have 6 fixtures, 2 bulbs per... I would like to switch, but, ... how did you justify the cost? - JimBollmanExplorerIf your RV has the small T5 Florescent tubes here is what I put in mine and they are great. You do have to disassemble the fixture and remove the ballast and do some simple rewiring, easy to do.
https://www.amazon.com/gp/product/B0795NLGS2/ref=oh_aui_search_detailpage?ie=UTF8&psc=1 - AlmotExplorer IIIMost RV owners know better than to buy from RV dealers :).
12V LED ropes start from $3 on Ebay, shipping included. Soldering isn't always required, some ropes come with cig lighter plug already. Or cut the adapter off and twist/tap into the nearest 12V light wire, if this is more convenient.
Didn't realize there existed prices $150/hour, but people with deep pockets might pay that much. It's a matter of personal choice - though, when chosen by somebody without really deep pockets, I would rather attribute this to laziness or stupidity (often same thing, one leads to another). Whatever makes "them" happy.
Having RV issues? Connect with others who have been in your shoes.24,316 PostsLatest Activity: Sep 13, 2025
