Gdetrailer
Nov 14, 2020Explorer III
BFL13 wrote:
Yes, using LED bulbs in the old fixture is a good choice. Powerfist is their home brand for lots of their things, so I will check the fixture for any other brand that might be on it.
When Mr Wiz gets back, he can say which Kohree he has that has the good voltage range from that amazon link.
Lots to choose from..
KOHREE AMAZON SEARCH
First one on Amazon list..
HERE
Relampable, 60K hr life, 6W with both lamps on 320 Lumens per lamp, "natural white" 4000K-4500K color temp..
LED type: SMD5050
Power: 6 Watts
Lumen: 2 X 320LM
CRI: Ra>70
Operating voltage: DC 12V-18V
Size: 11 1/4"(L) x 5"(W) x 1.5"(H)"
Much better specs than Princess Auto light, far brighter, only would need just one light on to equal brightness of the Princess Auto light.. Voltage range would be acceptable, narrow range would indicate it does not use a constant current switching regulator but with the upper rating at 18V should be fine to use.
This is an example of better lights designed for this kind of use.
