BFL13's avatar
BFL13
Explorer II
Nov 13, 2020
LED light and 12v Voltage? UPDATE-OOPS!/Got Kohrees too.
Update 15 Nov---the lamp was ok, it was a loose wire connection, my fault--apologies to all! 21 Nov -Got Kohree dimmable-very nice!
The other day I swapped out a standard dual ceiling light in the camper for an LED version. It was working fine on battery or at 13.6v at home.
Then had to charge the batteries so got on shore power with the converter at 14.7v. Very soon after the LED light went out and won't work on any setting for the two halves or to both ends at once. The other 12v lights (Non-LED) and fans etc all work.
Is it possible the 14.7v killed the LED lamp?
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    Some LED's are well designed and 13,14, 15, 16 volts wont' bother them
    Others are **** in the design department
    Some are even worse.
    My RV came with an LED to light up the grab handle. Nice and looked good save the design was ****.. It burned out very fast.. I replaced it and .. Same result. it burned out fast too. (NOTE I replaced just the LED)
    I then measured the resistor that limited current to the led 150 ohms. should have been 450 by my calculation. Replaced both the LED and the Resistor. 14 years later it still worked.
  • LED lighting for RVs is still in it's infancy.
    I have built LED emitters that stay cool and blast out high noon amounts of light on 2-watts consumed. The problem is the sizes of the heat-sink and 3.7 volt regulator. Properly built there just aren"t any reasons for these lamps not to work for decades. According to friends a 5 mm red emitter I set up on the coast in 1981 is still 24/7. That's 39 years. It's mounted on a service drop box.
  • the el chepo LED lights use a resistor to set the current to the LED. Problem One. LED's should be driven by a constant current. When the voltage goes up, with only a resistor to control current, current goes up. Then LED junction voltage goes down, further increasing current. You end up with thermal runaway, LED's can get hot enough to melt the solder joint or just fail.
    Good LED lights are more expensive, driven by constant current and generally say input voltage of 10-24V or more. Down side is the poor designed ones last a long time but put our RF that can interfere with radio.
    14.7V is more than enough to kill the cheap LED lights.
  • It's possible the LEDs you purchased will not tolerate the higher voltages. I have 18" ceiling LEDs in our MH and they have seen as high as 15.4 volts with no issues. You may want to ask the voltage question with your next purchase. eh?
    Richard
  • Did the LED manufacturer give you a range of acceptable voltages? Usually on the package or in the “instructions.”
Having RV issues? Connect with others who have been in your shoes.24,288 PostsLatest Activity: Jan 09, 2022
