Wisconsin Bums wrote:
The panel is a 2" square with 5 lights around the outside and one in the middle. On the panel it reads Bright Ideas LLC and the model number is SL206M2. It can be removed from the fixture as it's a puck 4" plastic fixture. It is hard wired to a switch. I tried to put a picture here but didn't know how to do that. Sure would appreciate any help. Thanks.
OK, well that is a bit more helpful.
Look like this? (hopefully the pix works)
If so, I found that pix at
ForestRivers Forums website from 2014The poster has the SAME problem..
I would have to say that the LED is junk, BUT you could STILL try the LEDs I mentioned. I think they will have no problem fitting since the LEDs I mentioned are about 25 mm around (about 7/8" in diameter.
You would need to cut the wires to the old LED then solder the wires to the LED module.
You might have to get creative with mounting the new module since the regulator parts are located on the back..
As far as posting pix, you need to use an online picture hosting site.
One of RV/net members has setup such an account that is free to use and automatically sizes the photos for the forum.
HERE IS THE LINK FOR PHOTOSUpload your photo to the website in the link above.
Then you simply copy the entire URL that page gives for that pix.
Then to add photos to your post you need to use the advanced post editor. To get that you need to use the "REPLY TO TOPIC" link (don't use the "Quick Reply" at the bottom of the page).
Oops, forgot, that photo host link does not need the photo posting, you can just paste it into your post..
Paste your URL into the box and click finished.
Then finish your text and post message..
