tenbear
Sep 11, 2013Explorer
MEXICOWANDERER wrote:
I use GOOP® the best adhesive on the face of the earth. I've used it in dripping 40C steambath conditions, 50C blow your brains out deathray heat, -30C and GOOP just laughs and keeps on sticking.
Just put in a fast note. Today mostly is follow-that-link day for LED's AGM's and other "mandatos".
I had an led panel that the double sided sticky tape wouldn't stick, so I glued it on with Goop. The Goop wouldn't stick to the sticky tape. I ended up putting a piece of paper on the sticky tape and then glueing it with Goop. Hasn't moved since.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
