MrWizard's avatar
MrWizard
Moderator
Sep 09, 2017
LEDs to replace 1076 dual pin bulb
i counted 16 bulbs to be replaced
some single bulb, some two bulb
dual pins 1076
need nice bright LED lamps or boards , no regulator no RF ?
these bulbs do not put out enough light, even though the put out too much heat, i found one 'defuser' cover with a hole in it
suggestions and links please
thank you
  • Try the following, SB
    or starbrightleds.com.
    The Starbright lamps are great quality but very expensive. The Panels are out of date as the newer generation LEDs are much brighter.
    Most of my fixtures are (were) florescent and I used led strips on aluminum and got too may, have to use SPDT to split into two intendancies.
  • Ivylog's avatar
    Ivylog
    Explorer III
    Ebay for $0.60 with 13 5050 (coolest running chip) to to $1.90 for 24 chips. Doubt you need more than 24 5050 chips in warm white.
Having RV issues? Connect with others who have been in your shoes.24,284 PostsLatest Activity: Jul 17, 2025
