skipnchar
Apr 07, 2014Explorer
AS long as it wasn't low on water it won't harm it. Sometimes a converter can boil water out of the battery which CAN cause damage but if you opened it up and found the plates covered it should be good as new. Usually it's a good idea to check battery fluid level about once every month or two until you know if your converter is causing it to loose water. I have to add a cup or so every 6 months on mine and it's left plugged in all winter every year.
Having RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 17, 2026
