Grey_Mountain's avatar
Mar 28, 2018
Lens for Bedroom Ceiling Lights
Looking for replacement lens for small, approx 3" diameter, lens for bedrom lights in my 2006 Discovery.
I have not been able to find a source.
Thanks.
GM
  • Cannot find a replacement lens. Found a 3" recessed can light that will work. $9.99 each. I will replace all eight lights.
    I now have seven good 3" recessed can lights that will fit the bedroom of a 2006 Discovery 39S if anybody needs them.
    GM
  • Contacted Fleetwood, got the following response - not any help at all.
    The lights installed in the bedroom area of your 2006 Discovery 39S are obsolete parts – no sub offered.
    We are unable to provide a direct sub or even parts of these lights.
    Our sincere apologies for any inconvenience this may cause you.
    Thank you
    Sindi Wilhelm
    Senior Parts Customer Representative
    REV PARTS
    https://parts.revgroup.com
    PRICE QUOTES ARE VALID FOR 30 DAYS
    PRICE DOES NOT INCLUDE SHIPPING
    P 260-724-5779 or 800-591-0628
    I found a possible replacement on the RV Interior Lighting Link.
    Thanks for all the replies.
    GM
  • JaxDad's avatar
    JaxDad
    Explorer III
    I had a similar problem with my rig, I took one of the lenses off the light in a cargo bay. They used all the same light fixtures everywhere in my coach.
  • j-d's avatar
    j-d
    Explorer II
    Almot wrote:
    With cheap LED everybody is now selling complete "lights" with fixture, not "lens". When you do find lens, they cost more than complete lights.
    Affirmative on that! Exactly what I found. New complete LED fixtures also pretty competitive with some of the better LED conversion kits.
    Just decided: Storage Bay Lights should be LED. That way when we bump the switch or otherwise forget that we left it ON and closed the door, we don't fry the lens, or run the battery down.
    Our coach is stored at home more than it's on the road. I leave an LED ceiling light switched ON. Reminder to switch the Disconnect to OFF.
  • Almot's avatar
    Almot
    Explorer III
  • j-d's avatar
    j-d
    Explorer II
    I take it there's not a brand name, part number, etc. any place you can see on the fixture (or lens if you still have it). Can you remove it and see if there's information on the back side?
    I needed a lens for a light in our 2003 Jayco. Marked as made by Command Electronics. Command is still in business and new coaches have Command lights. But... MY lens is discontinued. I ended up buying a new Command brand light that fit in place of the one that needed one of its two lenses. Now I have one spare lens.
  • I have tried Google, Camping World, Fleetwood...no luck. I'll try the link above and see what I can find.
    Thanks.
    GM
  • RV Dealers have a lot in stock and can order replacements also try amazon you may find it there. Google may help with other sources,
