RoyB
May 27, 2016Explorer III
I have found topping off is great if you have a battery bank at 90% charge already.
In my case when my batteries run down to the 50% charge state I have to start charging right away and due to the time restriction I usually only get to the 90% charge in a three hour time frame. If I had solar then the batteries will eventually get to the 100% charge state.
The problem with going all the way down to the 50% charge state first your batteries have put them selves in danger. In my case I start losing battery bank performance if I continually drain them down to the 50% charge state and then bring them back up to their 90% charge state if I don't do a full 100% charge state after 12 or more of these 50% to 90% charge state runs.
I guess crud builds up on the plates of the batteries that only a full charge will burn it off...
I don't think I have ever had a problem with a good full time trickle charge on the batteries if they were at least at the 90% charge state to start off with.
Guess all of this makes sense haha...
Roy Ken
Roy Ken
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
