fitznj
Feb 28, 2017Explorer
Gas is not your problem. It's an issue with the small rubber(?) o-ring that sits
under float-bowl valve. Gas with ethanol will harden the o-ring over time and fuel will leak around the o-ring and flood you engine.
I've had this problem on motorcycles and weed-wackers - replace the o-ring with one made out of Vitron (?) and problem solved. Draining the float bowl temporarily solves the problem.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
