pianotuna
Aug 26, 2016Nomad III
Hi Mr Wizard,
You have, IIRC, surplus acid telecom batteries. They are not nearly similar to Lifeline--and the maximum (safe) charge rate is c/5, not the minimum. So you don't need a bigger charger.
Starved acid AGM are entirely different beasts.
MrWizard wrote:
20 percent of 675 is 135 amps which is C/5
I will need a bigger generator and larger charge/converter to do that
