pianotuna
Jan 19, 2015Nomad III
Hi,
Allowing for inverter inefficiency means that a 1000 watt device may consume more nearly 100 amps, not 83.
Gene&Ginny wrote:
Lets try an over simplified example.
Watts = Volts times Amps.
If you want to run a 1000 watt microvave on 120 volts AC verses running it on a 12 volt inverter.
1000 watts = 120 volts times 8.33 amps
or
1000 watts = 12 volts times 83.3 amps
Continuous use on a 12 volt inverter would require 83 amps, that is a lit of current and requires a BIG piece of wire to handle that amount of current.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
