Aka_the_breeze's avatar
Jan 19, 2015
Let's talk about RV Inverters
Forgive me for being an electrical dummy , but I am... Is there a whole RV Inverter that would allow me to be self contained for a period of time ?? Maybe in place of a Generator ?? please explain the BASICS of an inverter/charger , or the like ??
  • Ron3rd's avatar
    Ron3rd
    Explorer III
    Depends on what you need to power.
    Oldman's links will bring you up to speed and reveal what you actually need. I use a 300 watt Pure Sine Wave inverter to just power TV's etc, nothing too demanding. There are 2000w inverters out there that allow you to run the microwave, etc, but you need a big battery bank.
  • All of these devices either convert energy from one form to another (with some loss in the process) or store energy.
    A 12V battery stores energy for later use.
    An inverter converts 12V DC electrical energy into 120V AC electrical energy. You need something that supplies 12V DC electrical power, which in an RV is a battery.
    A converter or charger converts 120V AC electrical energy into 12V DC electrical energy. This can be used to charge a battery, or to run 12V devices.
    A generator converts some sort of fuel (gasoline or diesel or propane) into 120V AC electrical energy.
    A gas tank or propane tank stores energy in the form of fuel.
    A solar panel converts sunlight into electrical energy. With an appropriate controller, this can be 12V DC electrical power. (Without a controller, it's rather variable depending on the light conditions and not usually all that handy for RV usage.)
    To be self-contained, you need to have an appropriate supply of energy for your needs. An inverter and battery bank can certainly be an important part of that, but you do need some source of energy to "refill" the battery bank, which is commonly either a generator or a solar setup. If using the generator, of course, its power source (the fuel tank) needs to be periodically refilled too. We don't have to worry about refilling the sun, thankfully. (When traveling, the vehicle's alternator is another possibility; this is a special case of a generator that produces 12V DC power and is itself driven by the vehicle's engine.)
  • Thanks for the links 2oldman
    I guess my search skills are getting out of shape.... Good links to get me started,, thank you
  • An inverter converts 12v to 120v, but feeds off the batteries. The more juice you use, the faster the batteries are depleted. So you either need more batteries (6-8) or minimize your 120v usage. AC is out of the question, microwave and hair dryers are marginal. You can watch a couple of hours of TV though and residential refrigerators use an inverter.
  • Yes, but you can't leave batteries out of the equation. A heavy load on an inverter eats batteries.
