theczar
Nov 10, 2016Explorer
Level Up 6 Point system issues
OK I took the camper out this weekend and had a problem with the Level Up system. I Backed into the site and lowered the Landing gear and disconnected from the truck. I pressed the auto level button and all started out well. Usually the curbside rear legs come down then the street side legs come down. The trailer does some adjustments and then all is level. What happened this time is the Curb side legs came down about 2-3 inches. The remaining legs dropped as expected and the leveling process completed without an error. The Curbside legs still in the up position. I put the system in manual mode and was able to lower the legs without issue.
The auto return function worked as expected too. I returned the legs to the retracted position, turned the system off then tried it again and again the same result. After searching the forum, I tried resetting the system (Removing the Fuse) and no change. So the bottom line is the Curbside rear legs will not drop to the ground in auto-level mode but work in manual mode Hoping someone here has some advice.
Thanks!
Thanks!
