leak at the jack, in the line leadung to the jack??? if at the jack it could be a seal. if the jack won't come down and you're seeing fluid on the ground in front of the RV it could be a bad solonoid valve. i had a leak in a hydraulic line that required surgery to fix.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
