wildbyon's avatar
wildbyon
Leveler System Not Staying Level
I have a 2011 Cardinal 5th wheel w/ auto leveling system. System seems to work fine, all four legs come in/out and system auto levels. Problem is that one side of the trailer will gradually lose approx. .2-.4 degrees of level overnight....enough to see and feel it in the trailer. None of the leveler legs has a leak. Only leak in the system is a small leak on a distribution block near the pump. Anyone else have this problem? Possible fixes?
  • Just wanted to follow up with my problem resolution... I found one of the leveler legs, on the side leaking down, had a loose hose fitting at the leveler leg cylinder. Started tightening it up and the whole fitting and hose blew off, hydraulic fluid everywhere. Cylinder fitting hole had been stripped out, head is aluminum, and fitting was just barely holding. Price to repair and rebuild cylinder was too close to cost of a new $500 cylinder. Lippertt does not sell just the top cap. Bought a new $500 Lippertt cylinder, installed and problem solved.
  • If no visible leak, then you have a leaking valve/seal in one of the legs or actuator valves allowing the fluid to seep back. Unless you are handy with hydraulics, probably time to bring it to someone who is. Not really any easy home rememdies.
  • I unplgged the solenoid and the block goes to the 3 slideouts.
  • if you have the Manual for the system, it should say which valve/solenoid and hose go where
  • Can't tell. It's on a block with three knobs/lines coming off one of the solenoid valves.
  • is that leak, on the hydraulic line going to the 'troublesome' leveler ?
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 12, 2026
