valhalla360
Apr 15, 2022Navigator
If you are setting up for regular use, get blocks that accommodate both but...
As long as the tire you block is fully supported, it's not going to cause a tire failure.
What many of those posting don't understand is the difference between static and dynamic loading.
- If I gently set a 50lb bag of sand in your arms, you can probably hold it.
- If I drop that same 50b bag from 10ft up, I'm betting you can't hold it.
That's basically what happens when you compare slowly pulling up onto a block vs hitting a pothole at 70mph. The forces on the tires hitting that pothole are several times what they will see slowly riding up onto a block.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
