- You just joined. You MUST post, Year/Brand/Model of RV for help. Also the Brand and model of the appliance. If not sure of model, just the Brand. There are upwards of 6 different brands of leveling systems. Doug
- 1492Moderator
- ADAD437Explorer
rockylarson wrote:
Generally lowering is an active process involving a pump or motor. Probable source of vibration. Raising on the other hand is usually passive using springs to pull the jacks back up.
depends on make. big foot is hydraulic both ways. no springs. - rockylarsonExplorerGenerally lowering is an active process involving a pump or motor. Probable source of vibration. Raising on the other hand is usually passive using springs to pull the jacks back up.
- harold1946ExplorerElectric or Hydraulic jacks?
