rockhillmanor
Jan 12, 2019Explorer II
You said putting a board under the plastic lynx blocks results in everything slipping when you drive on the stack.
You are supposed to pyramid the blocks. So the tire climbs the pyramid which eliminates any slipping.
And yes you will have to buy a second pack to use when a higher lift is needed so you can pyramid the blocks properly.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
