profdant139
Jan 13, 2019Explorer III
rockhill mentioned the issue of slipping. Whether I put a piece of plywood under the stack or over it, the plywood does not stay perfectly in place. The Lynx blocks, of course, move as a unit, since they are interconnected.
That is why I think that the best solutions are (1) a thick rubber mat (which should not slip in contact with the blocks) or (2) putting the plywood under the higher tire if needed, in order to avoid the dreaded "in between the blocks" syndrome, described above.
I should add that since we do a lot of boondocking in very rough terrain, this whole issue is not just theoretical. We are not on a concrete pad, or even on gravel -- we are often on a mix of rocks and dirt.
Finally, since I am lucky enough to have a spouse who loves really remote boondocking, I will happily do whatever it takes to keep her happy - - if that means fiddling around with the leveling blocks, I will do that!! ;)
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
