rockhillmanor
Jan 14, 2019Explorer II
Stop adding the wood.
I've been rv'ing all over and show in a sport that is always on ground of all types including sand. I just use the blocks and if you drive 'slowly' up on them and 'on spot' they don't move. Run at them and they will move!
the picture I posted for an example was the honey comb type.
I immediately found out when crossing into Florida with all the sand that that type of blocks just shattered into pieces when used on ground.
I switched to the solid ones and no problem. Key is placing them pyramid style. Which gives you the gradual lift for the tire to climb up on. I also will scratch the ground if there is a lot of sand with a simple hand held garden tool with tines, then place the blocks in the indentation.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
