3_tons
Apr 10, 2021Explorer III
pianotuna wrote:3 tons wrote:
“ The only reason folks think lithium chemistries are more complicated is that they have come to accept all the requirements of lead acid as 'normal'. In an apples to apples comparison the care and feeding of lithium is far simpler, most folks just aren't familiar with it. ”
Exactly, Lithium (LFP) is happy with constant current and constant voltage, isn’t bothered by a float mode and there’s no need to equalize...This is about as basic as things can get and describes what a dedicated LiFePo4 charger does...The main caveat, don’t charge below freezing (discharging is ok).
3 tons
And SiO2 are less problematic than Li, with even fewer hoops.
Well that seems to be the answer to the question that nobody asked :), but not a whole lot different than comparing a biplane to a Lear jet - either will get you where you want to go (lol).
3 tons, where ‘harvest rates’ and capacity matters...
