pianotuna
Apr 10, 2021Nomad III
FWC wrote:
As we have discussed to death, even the "don't charge below freezing" caveat is really a soft limit, worse case you have fractional decrease in cycle life. To do and apples-to-apples comparison, lead acid also have a low temperature charge limit, and this is usually a hard limit - you try to charge below the freezing point and very bad things can happen.
Do provide a link.
That freeze point would be for a totally discharged battery? What sort of idiot are you that you would contemplate charging a frozen battery?
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
