StirCrazy
Apr 11, 2021Moderator
otrfun wrote:
When I called Battleborn a few months ago, they said it was ok to float their batteries for weeks/months at a time between 13.2 - 13.8v. They do not recommend floating their batteries at 14.4-14.6v for more than a few weeks.
Interesting to note that Progressive Dynamic Lithium/LifePo4 converters are single stage 14.6v converters. Not a good match for BB for long periods of storage/non-use.
that because to get to the true 100% it takes thst 14.6, but the "other" 100% you only need 13.6. I am setting mine up with a converter that I can taylor the output so normaly Ill use it as a 13.6 single stage, but I do have the capability to use it as a 14.6/13.6 duel stage which Ill probably use when it is sitting at home for the winter and I want to top it up once and a while.
Steve
