StirCrazy
Apr 11, 2021Moderator
pianotuna wrote:3 tons wrote:
“ The only reason folks think lithium chemistries are more complicated is that they have come to accept all the requirements of lead acid as 'normal'. In an apples to apples comparison the care and feeding of lithium is far simpler, most folks just aren't familiar with it. ”
Exactly, Lithium (LFP) is happy with constant current and constant voltage, isn’t bothered by a float mode and there’s no need to equalize...This is about as basic as things can get and describes what a dedicated LiFePo4 charger does...The main caveat, don’t charge below freezing (discharging is ok).
3 tons
And SiO2 are less problematic than Li, with even fewer hoops.
except they are way more expensive and you cant recover the overnight use very fast with there charge limits, and they are big and weight a lot and dont have the usable AH LFP does. I can live with that cold charging wall.
Steve
Having RV issues? Connect with others who have been in your shoes.24,404 PostsLatest Activity: Aug 07, 2026
