FWC
Apr 11, 2021Explorer
Below is the same data for LiFePO4 cylindrical cells. Note that even at 10C (!) you should still get 98% the rated capacity. The flat discharge curve and a Peukert exponent very close to 1 make lithium a much better choice for high loads. At 0.65C with lithium, you would have 2.5x the usable capacity.
In terms of SLA, a dual purpose AGM should also preform better than SiO2 as the Peukert is also closer to 1.0. I gave you the table for Odyssey before and it was 50% higher usable energy.
