FWC
Apr 11, 2021Explorer
Any BMS that uses contactors as opposed to MOSFETs, or assuming you are running an inverter (at 10C), use the BMS to shutdown the inverter as opposed to shutting down the battery.
However, I seriously doubt anyone will be running at 10C, this was to illustrate that lithium retains its capacity at high discharge rates. As BFLs example illustrates, even at a 1C rate lead acid is only good for about 1/3 its rated capacity.
